first you must Zincate the part then you can either go to nickle then chrome....or nickle strike(or flash copper), acid copper, nickle then chrome. If you get poor results, try Zincate, then strip in a pickle solution, zincate again then proceed as described above, this ensures you get a good zincate coating proir to nickle.
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 12:16 PM |
| Stripping chrome plating from aluminum | bbqboyee | Anodizing Questions | 4 | 04-22-2006 01:22 AM |
| Nickel plating repaired & filled aluminum? | Bill-26 | Electroplating Questions | 0 | 12-20-2004 11:48 AM |
| Plating Aluminum | rdcycle | Electroplating Questions | 2 | 06-09-2004 08:32 PM |
| Plating aluminum on steel | TheMartin | Electroplating Questions | 0 | 04-23-2004 07:26 PM |
