after i bead plast my fasters for plating, should i do any thing else before i put them the in the copy cad solution? the book implies going straight from bead blast to the coyp cad. seem like some cleaing should be required. like muratic acid or sp degreaer.
please advise. thanks chuck |
The instructions are correct. Put the part straight into the plating tank.
You are confusing two completely different things
Surface area has no bearing on mass - or weight For example: a 1" cube of marshmallow = 6 sq" surface area and 1/100 oz in weight a 1" cube of lead weight = 6 sq" of surface area and weighs 1/2 lb (approx)
I understand weight and area are completely different. I'm trying to understand how you determine an easy way to determine the surface area of a bucket full of small nuts and bolts. do i need to calculate the area of each bolt and nut and add them all together to determine the amound of current to use?
I was thinking that for each pound of typical automotive nuts and bolts, so much current would be applied. I'm wondering how many of the nuts and bolts i do at one time. I have the one gallon cad kit. Thanks for the help, i'm wanting to do the plating and any help would be greatly appriciated. Chuck |
At the end of the day:
IMAGINEERING AND GUESSTIMATION will get you into the ball park!
| Copy Cad question | bkpierce | Electroplating Questions | 1 | 08-03-2004 10:17 PM |
| Copy Cad acidity question | aermakov@rogers.com | Electroplating Questions | 1 | 05-16-2004 11:32 AM |
| Copy Chorme question | polishinginc | Electroplating Questions | 3 | 09-21-2003 01:09 PM |
| Question about voltage and Copy Cad | Matt Harwood | Electroplating Questions | 1 | 03-20-2003 07:34 PM |
| Plug N Plate Copy Chrome question | Great_Scott | Electroplating Questions | 5 | 03-20-2002 06:53 PM |
