+ Reply to Thread
Results 1 to 7 of 7
Thread: Alternate solution heating idea?
  1. #1
    Join Date
    Feb 2004
    Posts
    109
    Default Alternate solution heating idea?
    This might also apply to the anodizing forum, but what I am thinking of would be for a dual plating/anodizing workbench set-up. Has anyone has any success trying to use copper tubing to plumb hot water around the plastic tanks with insulation wrapped around it as a heat source instead of the ceramic heaters? By using a hot plate heated main water tank and a water pump to circulate the heated water (controlled by valves) through the tubing around each of the tanks that need heating, would that transfer enough heat through the plastic (if both the tubing and the tanks were wrapped in insulation)? Just trying to figure out some way to avoid having to buy all the different heaters needed to set up a dual set-up for both chroming and anodizing.
    Share with Facebook
  2. #2
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,794
    Now you've introduced copper into the tank. This will contaminate a nickel tank and really screw up anodizing. No, the Caswell heaters are the best
    It isn't broken!
    Have A Web Site?
    Share with Facebook
  3. #3
    Join Date
    Feb 2004
    Posts
    109
    Oh, OK, I realize I didn't express it right. What I was thinking of was wrapping the copper tubing around the outside of the plastic buckets/tanks, and then wrapping around that with insulation.
    But on the subject of the tank heaters your kit uses, won't it mess up the solutions to move them from one tank to the other, or does each tank have its own dedicated heater(s)? Also, if I am trying to set up a bench with both the triple chrome and LCD processes, could they both share the same SP Degreaser tank? Thanks.
    Share with Facebook
  4. #4
    Join Date
    Dec 2003
    Posts
    201
    Just my opinion, but running all that copper tubing (you probably want at least 3 or 4 wraps for a 6 gal bucket), valves, pumps, insulation and a sorce for heating up the water sounds like it might be more expensive in the long run than just using the heaters. What size of kits are you thinking of buying. If you get the Caswell 4.5 gal triple chrome kit, it comes with all the heaters in the kit, one for each solution, then you would only need a couple more for anodizing.
    As far as using the same heater for different solutions, I don't think that would be a problem as long as you rinse them well between solutions. I WOULD USE A SEPERATE HEATER FOR THE CHROME AND ONLY USE IT IN CHROME. If you rinse the heaters and switch tanks, then wait an hour or so for it to get up to temp, you might find that having a heater for each solution is well worth the cost of your time.
    Hope this helps.
    Share with Facebook
  5. #5
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    you would be much better off with having a heater for each tank that needs one instead of having to switch back and forth and cleaning 100% inbetween changing from one to another. you would have at least 5 times invested in copper pipe-insulation-water heater,ts,elbows etc etc for what a heater would cost.
    bill
    Share with Facebook
  6. #6
    Join Date
    Feb 2004
    Posts
    109
    OK, so much for that idea. Thanks for the input from everybody. My funds are tight, and I'm trying to save enough to set up a small hobby business doing both chroming and anodizing, and am looking for ways to save where I can on costs. Never hurts to ask.
    Share with Facebook
  7. #7
    Join Date
    Aug 2004
    Posts
    110
    The ohter thing - I know this is a bit old but I was just lurking - is that your copper pipe idea still lacks temp control does it not?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. trouble plating with 18K fast gold solution
    By didierphmartin in forum Electroplating Questions
    Last Post: 05-06-2008, 02:51 PM
  2. gols plating solution gone bad??????
    By clocktools in forum Electroplating Questions
    Last Post: 04-08-2008, 10:09 PM
  3. Temperature of Caswell gold solution
    By apricotscrub in forum Electroplating Questions
    Last Post: 03-13-2004, 06:36 PM
  4. I know your gold plating solution is cyanide free, but...
    By tbloss001 in forum Electroplating Questions
    Last Post: 07-30-2003, 02:23 PM
  5. 14k gold solution
    By Rusty Armstrong in forum Electroplating Questions
    Last Post: 04-05-2002, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
