I was wondering if you can zinc plate with the brush plating techque for instance a voltage regulator or horn relay,you can't take it apart and your only doing the base and mounting legs,or does the tin look just like it.
I getting ready to order a workshop,do I need a power supply,I have a 50 amp and 10 amp battery changer as well as car batterys,how about for brush plating can I use the same one?
Thanks
Frank :P
