Here is some info on black oxide from several sources:
Subject: FW: black oxide
The black finish on 50-60's Ford fasteners is S-2, Phosphate and oil. It is a
little more gray than black oxide. It can be produced by soaking fasteners in
OSPHO for about twenty minutes and then spraying W-40 or the like on them.
Ospho is a commercial solution of phosphoric acid available at such places as
Ace Hardware Stores. Eastwood also sells a solution that can be used.
Here is another way to do this and not have a problem... Wire wheel parts/nuts/bolts....mother-in- law........drop them into the acid used to clean bricks and cement...(available at any hardware store in gallons for pennies...muriatic)...take them out after you swish them around for a minute or so... and drop them into clean water...USE A HOT DOG TONGS..the acid will burn you...After you swish them around in the acid..drop them right into the heated parkerizing solution...after they are colored...about 8 to 10 minutes....dry them good...then spray with the WD40...You now have a properly "phosphated" piece...Do not get ouil on the parts between the acid and the chemical bath...you will get streaks and stains on the parts.. If you need the phone number of the best chemical on earth for this..let me know...I have been using it since the 50's...even while in the Military to do our weapons..
It is not a "cold" application..nor is it a paint. Paint would come right
off when you put the bolt on with a wrench...To apply the chemical
coating..it requires about 185 degrees in a very friendly chemical.. It will
not burn your skin..nor will it ruin your day ...BUT..if you get it on the
wife's stove top..then all bets are off..SHE will ruin your day for sure. It
stains stove tops...and can not be cleaned up. Best way to use it is outside
on a barbie or a camp stove... Parts can be colored in a coffee can...and it
is very simple...
The US Military has used it in 2 main colors..BLACK and GRAY since 1918 for
"parkerizing" weapons. It helps prevent rust...it applies a gray ZINC
coating to steel...or in the case of the black..it is MANGANESE..
I do at least 2 batches of parkerizing a week...Finished products look
better than new..No..I only do for me..and locals...
> Very simple..You have to buy a quart of the chemical from Vern Owens down
Ø south. 864-246-3836
Ø You put an ounce or 2 in the
> can...get it to the 185 degrees and drop in the parts..
> First though..they must be "wire wheeled"..and cleaned real good... I use
> sand blaster and go right to the chemical.. But, the wire wheeling and
> rinsing works fine..
LinkBack URL
About LinkBacks
