Connect with Facebook
Closed Thread
Old 04-23-2004, 04:15 AM
dagobert
Default reading temps on tanks
Hi. Getting the last of my plating setup put together, and I was curious. You suggest a fish tank thermometer to check the tempratures of the various steps. Would an IR thermometer aimed at the liquid's surface also work? That way, it could also be used to measure the temp of the parts going into the solutions, and the one thermometer could be used without cross-contaminating the tanks. Thanks.
Closed Thread
compressor tanks 11111111 Powder Coating Questions 8 11-02-2004 11:37 PM
Dealing with thermal shock / high temps AresP Electroplating Questions 0 08-13-2004 09:08 AM
IR Thermometer reading trouble and fully cured questions Bud Powder Coating Questions 1 07-20-2004 06:36 PM
testing tanks rayman9969 Electroplating Questions 0 04-26-2004 07:49 PM
Container to use as anodizing tanks? Tim Wiltse Electroplating Questions 1 12-30-2002 02:08 PM
