Old 04-27-2004, 02:55 PM
Daveleeander
Default Plating Hyd. Valve Spools w/ Hard Chrome
I want to recondition some old Hyd. Valves on a tractor of mine. I want to ream out the valve body until the surfaces all clean up, and then instead of turning new spools to size, I would like to plate them until they reach the proper size. Before I go to the expense of buying a kit, learning to use it, etc. I thought I would ask about the feasibility of doing this.
Question: (1) Can I polish the old spools (chromed if it isn't worn off) and add more chrome to existing, or do I need to grind off (in lathe) any old finish first.
(2) How accurate can I expect to be (with some practice) as far as thickness of layers with time (I have the on line manual and have read the hard chrome portion).
Dave
hard chrome plating dcarter Electroplating Questions 4 04-27-2008 10:21 PM
Hard Chrome Plating Help dg5240 Electroplating Questions 0 05-31-2005 03:17 PM
Need help hard chrome plating an internal diameter... ld2222 Electroplating Questions 6 12-31-2004 05:15 PM
hard chrome plating dcarter Electroplating Questions 1 12-26-2001 11:43 AM
