Old 05-17-2002, 12:46 AM
GolfNut
Default Beginner Plating
I want to plate a few putter heads (soft carbon steel) and I have a few questions.
1. What's the best way to remove old plating or paint.
2. I've read on this site that you need a strike layer of nickel BEFORE you plate copper. Elsewhere, i've heard of people plating putters with copper (soft) and plating nickel over it for durablility and finish. What should I do?
3. What kit should I use? I want to try the Plug-n-Plate first, but I'm wondering if I can dip the putter head into the solution?
THANKS!
Many of life's failures are people who did not realize how close they were to success when they gave up.
- Thomas Alva Edison
Old 05-17-2002, 01:32 AM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Beginner Plating
1. You can sand-blast, grind etc. or strip chemically using an acid pickle...formula in the manual from easy to get chemicals.
2. To plate copper directly onto steel, commonly a cyanide based copper is used. We try to avoid selling cyanide based products, for obvious reasons, so have a very effective acid copper system instead. This means if you want to plate copper over steel, you need a nickel plate first.
I would get a nickel/copper combo kit. http://www.caswellplating.com/combo.htm It's much more versatile than Plug N' Plate.
Have A Web Site?
Old 05-17-2002, 10:09 PM
GolfNut
Default Re: Re: Beginner Plating
THANKS!
Ok.. I looked at the nickel/copper combo. I'm thinking of getting it. Can I use this combo to nickel->copper->nickel plate a small piece? THEN, what do I do with the system? Can I reuse it weeks/months/years later? $155 seems a little steep if I'm only going to do 1 small piece... How much can I reuse this system?
Also, I already purchased the plating manual (but haven't received it yet). Can I get a credit for the price of the manual?
Does anyone know how to treat raw carbon steel to get that OILCAN look?
THANKS AGAIN!!
-GolfNut
GolfNut947@Yahoo.com
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 10:11 AM
Nickel bath inexplicably quits plating jackf Electroplating Questions 5 01-25-2005 10:55 PM
Beginner needs help (Brass Plating) KramYellek Electroplating Questions 0 06-02-2004 03:31 PM
plating and size power? chromo Electroplating Questions 7 01-18-2003 03:52 AM
Electroless Krome plating Q's chcarver Electroplating Questions 1 10-10-2002 11:00 PM
