Connect with Facebook
Closed Thread
Old 05-17-2002, 05:23 PM
magfinpete
Default tripple chrome, nickel chrome, copy chrome or electroless ch
Old 05-19-2002, 01:52 PM
48Buick
Default Re: tripple chrome, nickel chrome, copy chrome or electroles
Hi:
If your doing a boat I would definently go with nickel and then chrome. The nickel will tarnish in time and then your back to dull looking parts.
Chrome will protect them.
You could do all the prep work (buffing,sanding,polishing) and then use electrolytic nickel on them. For 60-70 square inches you will need less then 10 amps.
Then you could pay a plater to put the chrome on. Its a lot cheaper that way, as you have already done all the work!
You might not want to use the electroless nickel for outdoor use. Its thinner and eventually the solution runs out of nickle.
Good luck
48 Buick
Closed Thread
Differet copper plating questions, plus copy chrome/ nickel? krsimulis Electroplating Questions 1 07-26-2004 01:25 AM
Electroless Krome VS Copy Chrome plating? qwik3r Electroplating Questions 3 04-29-2004 12:39 AM
Price of Copy Chrome vs. electroless Krome plating dwthomas Electroplating Questions 1 05-14-2003 11:01 AM
Chrome, Nickel or copy chrome? dwthomas Electroplating Questions 1 02-15-2003 02:49 PM
Electroless Nickel over Chrome gglines Electroplating Questions 1 05-13-2002 12:09 AM
