Old 05-21-2002, 05:38 PM
brendan hedges
Default support
this may sound like a silly question but, how do you support the items you want to plate so that they get an even coating all over. and also how would you stop the plating process from adhearing to certain parts. for instance, i have some hinges i want chromed but i do not want the hinge pins coated, just the metal support for the pins?
thanks in advance
brendan
dumb questions from a newee, well they may be for you but not from me. heh heh heh.
Old 05-21-2002, 07:21 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: support
You are hanging the parts into the plating solution from a bar that sits on top of the tank.
The part is hanging on a piece of copper wire, into the solution.
You can't stop a little piece of the wire from being plated, so you have to try to connect the wire to the part in a non conspicuous area.
You can use tape, or a masking lacquer (search our site for masking lacquer)
In the case of your hinges, why not just disassemble the hinges and only plate the support sections?
Have A Web Site?
Old 05-21-2002, 07:42 PM
brendan hedges
Default Re: support
thanks for your reply.
if plating small items such as self tapping screws would you have to wind copper wire into the thread of each screw? or could you start the tread in to a sheet of plastic so they all stood upright in regimented rows?
thanks again
brendan
Old 05-21-2002, 07:44 PM
brendan hedges
Default Re: support
by the way, your uk server and email address is down.
Old 05-22-2002, 01:37 AM
mcaswell's Avatar
Caswell Inc Founder
Default Re: support
You could do either.
Have A Web Site?
Hard chroming? motorbuilder Electroplating Questions 9 07-23-2005 04:35 PM
Requesting Support From Caswell Inc. mcaswell Electroplating Questions 0 12-07-2003 07:03 PM
which kit? skeleton Electroplating Questions 2 05-12-2003 06:43 PM
Why no Tech Support on open Forums?? Tim Wiltse Electroplating Questions 1 03-20-2003 02:48 PM
Great support! Follow up/ update chromo Electroplating Questions 0 02-04-2003 10:51 AM
