+ Reply to Thread
Results 1 to 3 of 3
Thread: What is the best way to mask threads and holes?
  1. #1
    Default What is the best way to mask threads and holes?
    I am about to start plating after weeks of polishing. My first parts have alot of threads and holes that cannot change diameter, and one part is a master cylinder where I don't want to get plating inside. I am using the copy chrome and wanted to know what was resistant to the solutions and the plating. I thought plastic like what is on the buckets would work, not really sure. Thanks in advance.
    Kenny
    Share with Facebook
  2. #2
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    any type plastic plugs will work well there is also tape specific for plating you can use to cover threads. i believe caswell sells a kit with various sizes of plugs.
    bill
    Share with Facebook
  3. #3
    Join Date
    Feb 2004
    Posts
    109
    Default Green slime...
    Caswells also sells a green plastic substance that you can paint on the part, plate, and then remove with laquer thinner. I just finished plating some motorcycle parts with it, and will report on my success or failure here in a little while.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
