+ Reply to Thread
Results 1 to 8 of 8
Thread: Need help on what area to calculate to determine my amperage
  1. #1
    Default Need help on what area to calculate to determine my amperage
    I am about to buy a recitier, and I am having some problems deciding on what to buy. My parts are small, but there are bigger ones to. I am going to use the copy chrome (its on the way) and I have parts between 15 and 30 square amps. And they are not all the same. My first question is, do I need it to be exact. Can I use 2 amps if the square inches is around 42 square inches, which would require 1.5. Not sure on how exact you need to be. Also, when I calculate the surface area, do I calculate the entire surface area, or just the area that is not masked off. Or, do I calculate the entire surface area if I am only doing the front. Please help me so I don't buy the wrong rectifier. I am going to need between 1 amp and 4 amps, and I want one rectifier to do the job, looks like I need two, which I don't want to do. I have spent enough money already.
    thanks,
    Kenny
    Share with Facebook
  2. #2
    Join Date
    Jun 2003
    Location
    BUCKEYE,AZ
    Posts
    16
    Default copychrome-amps & area
    hello krsimulis. You should be pretty close on the amps to area ratio. I have the copychrome and I am using a 12v battery with a charger and light bulbs which works really well for me. I have plated up to 80 sq.in. You only need to figure the unmasked area. Hope this helps. lloyd
    Share with Facebook
  3. #3
    Glad to hear you are getting good results. I just posted another question about my first plate, it went all wrong. Are you plating aluminum, or other metals. Also, how big of a copy chrome kit are you using, and how many amps are you using. I might change over to a 12V system instead of a 6V system. Ill try anything right now. You know I didn't read your reply before I plated, wish I had because I calculated area wrong the first time. Let me know how you have your agitator submersed. I would really like to hear about your setup, it might help me figure out what I am doing wrong.
    thanks,
    Kenny
    Share with Facebook
  4. #4
    I just thought of a question I had right when I walked away. Lets say you have a flat piece, and you only want to plate one side. If I don't mask the other side with a laquer or anything, do I still need to count that in my area that I am calculating, or do I only count the area that will get plated. Or should I mask it. I also forgot to ask you where you got your bulbs from
    thanks,
    Kenny
    Share with Facebook
  5. #5
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    kenny,
    only calculate for the side you want to plate onto, also from the other post about the copper pipe only calculate the ouside area. if you calculate area into a piece that wont wind up getting plated anyway you will more than likely burn the plating.
    bill
    Share with Facebook
  6. #6
    Join Date
    Feb 2004
    Posts
    109
    Default What about the plate on the shadow side?
    Quote Originally Posted by bhhodges
    kenny,
    bill
    Your expertise in this is WAY beyond mine, but in the above advice, if he is only going to count and plate the one side without masking the other, shouldn't he at least move the two anode plates together, or even just remove the one on the side he's not trying to plate? (Line of sight and all) Or am I mistaken? (Quite possible)
    Jay
    Share with Facebook
  7. #7
    That is what I am doing. If I am only going to plate one side, I am only going to have one anode pointing that way. And if that side is longer, then I will use both plates on one side.
    thanks,
    Kenny
    Share with Facebook
  8. #8
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    jay
    your right on the money i only meant dont calculate the inside of any hollow item if your not gonna plate it.
    bill
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Calculating Surface Area, the Easy Way.
    By PrecisionPB in forum Anodizing Questions
    Last Post: 05-28-2005, 02:56 PM
  2. Anodizing without knowing surface area?
    By sbpoole in forum Anodizing Questions
    Last Post: 01-06-2005, 07:09 PM
  3. Calculating the surface area?
    By GramSlam in forum Anodizing Questions
    Last Post: 09-26-2004, 10:18 AM
  4. work area vs. cathode area
    By elton10 in forum Anodizing Questions
    Last Post: 03-25-2004, 09:59 PM
  5. Surface Area vs. Current
    By shorton in forum Electroplating Questions
    Last Post: 11-06-2002, 11:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
