I have been preparing for this first plate for a long time. My first two pieces came out worse then I could have imagined. The first one I tried to use the copper pipe. That piece came out dark grey, and it had little spots that weren't plated. I could see little spots everywhere. I think I mis-calculated by adding the area on the inside of the pipe. So the second piece to test, I tried a piece of aluminum that I could risk loosing. This piece came out really spotty, and it looks like the zincate didn't come all the way off. You can kind of see it in the pictures. The edges have plate on them, but the flat surfaces look like they have streaks of plating, or like molten lava. I will list everything I did, and everything I used below so you can know what I am using. One thing I can tell you is I keep my area perfectly clean, to the point where I am anal about not contaminating my plating solution.
I bought the 3 gallon copy chrome kit, with the zincate to plate aluminum. I put the distilled water, the two bags of crystals, and the two bottles of brightner in the bucket together and let it set. for 30 hours. I first put the heater in (the one with the plastic guard) so the solution can heat up. I hung my anodes by copper wire by cutting the top two corners and running the wires through the cuts, then bending the corner over the wire, and hung the wire over the side to hold the anode up. I didn't let this copper wire touch the solution. I then stuck my agitator in with the top of motor case just outside the solution and everything else submersed.(wasn't sure how to put that thing in, but it seemed to work) I made my copper bar from 1/2 inch copper pipe with the end beat down and bent over the sides, with two small holes drilled in the middle to run the wire through. For a power source, I used a lawnmower 6V batter, and bought ( I got the impression afterwards that I shouldn't have put both of the bottles of brighter in when I made my plating solution, not sure though. I also don't know if I should have used 12V instead of 6V. I thought I read that 6V would be better for my situation. I figured the first part was "burnt" because I used too much current by counting the area inside the tubing. It was dark grey, milky looking, and you could see spots where it did not bond. I am pretty sure I didn't contaminate my solution. I keep it sealed, and I wear non-latex gloves if my hands need to go into the solution, and I take the cleaning seriously. If you can help me, I come over and mow your lawn, wash your clothes, paint the house, whatever. I am worried I have screwed up my solution some how. Also, does anyone know a good way to handle your part from rinsing it to the bath. I use lint-free, non-abrasive cloth painter rags. You can send me an email, or even call me if you want to, or I can call you and save the charge. I can't let all this money invested go to waste. ![]() ![]() |
From doing a little research, I am starting to get the feeling that I had a problem with the zincate and contamination. In the book it talks about plating out onto a dummy corrugated cathode. What is that? I am going to test the PH in the morning, and I am assuming I use the same stuff you would use in your pool to adust it.
thanks for all the help in advance. Kenny |
For the copper pipe, I first sanded off the little numbers and any burs from cutting and drilling it. I used the Aircraft Remover laquer thinner to do the initial clean. I then rinsed this off with soap and hot water and a kitchen sponge. This removed everything very well. I had then dropped it into a kitchen pot on the stove with the SP Degreaser at 150 degrees. After around 2 minutes, I took it out with some rubber gloves and sprayed distilled water on it from a bottle. I used a lint free non abrasive wrag to rub the part down while I was spraying to make sure everything came off. I had also dipped the wrag in distilled water before rubbing. I then let it dry on top of the same type of wrag. I then wired it up with non latex gloves. This was the first piece , and I can't guarantee that I did not touch it with my hands, but I am pretty sure I was careful not to. Another thing though, the copper wire that I hung the part from was not protected from my hand.
thanks, Kenny |
kenny,
the cleaning steps sound right on track except dont dry the part off after spraying the part off with distilled water, go right into the bath wet and make sure the water forms a sheet of water on the part without and beading up at all. feel free to send me a phone number via e-mail and i can call you if you want. bill |
kenny
i replated a copper pipe that i had plated before with nickel. i replated it with copper and then plated it with nickel i also added 10 pictures of the step by step process at my web site that might help you out . the last 10 pictures are the ones i did today with a description at the bottom of each one. my web space wont let me add a lot of text with each picture but im sure the pictures will make it clear anyway. http://home.comcast.net/~jhodges87/wsb/index.html |
Bill,
Man your piece looks nice. There has to be some fatal flaw in what I am doing for it to come out so bad. I just dropped it in the bath, and I think I did it right but we will find out. I have a question about preparing the anodes before you put them in, and when you take them out. Before I put them in the first time, I put them in the degreaser and cleaned them. When I took them out after plating, I rinsed them off with distilled water and wrapped them in the little bandages that came. When I went to put them back in just now, I put them in the degreaser again (just in case there was **** on there from last night) and rinsed them with distilled water again before dropping them in. Let me know if that is correct, and what is the purpose of the bandages. Also, if there is contaminate in the solution, can I used one of the plates as an anode, and the other plate as a cathode, then turn it on for a few minutes. I figured after that I would take the cathode plate out and clean it thoroughly. Let me know if that makes a difference. thanks again, Kenny |
