Old 06-15-2004, 03:23 PM
sags_3
Default Different Gold Anodes
I read on an old post that if using a gold anode instead of the stainless steel anode, the gold is used up straight from the anode.
If I use a rose gold ring as my anode, will the finish be in rose gold?
What difference does the Fastgold make. I don't think I can but it through the UK supplier for Caswell, but ould like to know.
Old 06-22-2004, 06:20 PM
Moderator
bhhodges is on a distinguished road
i dont think you will be happy with using a rose gold anode with a 24k gold plating solution. if you look around on the internet you can find gold anodes in 14 thru 24k for around 30 dollars us . the fast gold is a brush plating solution that has a higher gold content than a tank solution and i highly recommend it, i use it for all my gold work.
bill
Old 06-23-2004, 09:54 AM
sags_3
What would happen if a rose gold anode was used?
Am I am able to use 14k anodes with the 24k solution that comes with the plug and plate kit?
Old 06-23-2004, 04:03 PM
Moderator
unless im mistaken i think caswells gold tank or brush plating solutions are all 24K so if you use anything less than a 24k anode i dont know what results your going to get .
bill
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 09:11 AM
Going For The Gold gsw3 Electroplating Questions 3 09-11-2005 12:18 PM
How about Gold on Gold ? Ra Electroplating Questions 5 10-12-2004 07:47 PM
Silver polish on 24k gold plate?? chromo Electroplating Questions 3 04-07-2003 05:14 AM
gold plating on brass jomida Electroplating Questions 5 02-23-2003 10:34 AM
