+ Reply to Thread
Results 1 to 3 of 3
Thread: gold plating solution gone bad?????? anyone from there ??
  1. gold plating solution gone bad?????? anyone from there ??
    I opened a bottle of 24K gold plating solution I purchased about a year ago. I noticed that the gold had deposited on the wall of the plastic bottle.
    After shaking up, most of the gold came off the bottle and settled to bottom. I now have a light green liquid with what looks like flakes of gold leaf on bottom. Is there a way to put the gold back into solution or should I write it off as a bad buy.
    Thanks,
    Jerry
    Share with Facebook
  2. Re: gold plating solution gone bad?????? anyone from there ??
    1 gm gold chloride
    75 gm sodium phosphate
    2,5 gm sodium sulphite
    1 lit de-ionised water
    I have had the same problem and although posted a long time ago (and tonight too), I never had a reply.
    the items above however will make a brush plating solution for pure gold that works well apparently. Just need to only make up as much as can use in a few months - as it too "goes off".
    Mark
    Share with Facebook
  3. Re: gold plating solution gone bad?????? anyone from there ??
    I too have seen this "recipe" for a gold plating solution. I actually made some up, and it worked pretty well. BUT, I did get a brown precipitant out of solution when mixed. Anyone know what that might be? I'm thinking it might be elemental sulfer.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. gold plating on brass
    By jomida in forum Electroplating Questions
    Last Post: 03-28-2009, 06:41 PM
  2. Question on gold plating
    By oldtoys1961 in forum Electroplating Questions
    Last Post: 05-07-2008, 10:41 PM
  3. trouble plating with 18K fast gold solution
    By didierphmartin in forum Electroplating Questions
    Last Post: 05-06-2008, 02:51 PM
  4. Gold Plating and Nickel plating
    By tzmandevil in forum Electroplating Questions
    Last Post: 09-16-2005, 09:11 AM
  5. I know your gold plating solution is cyanide free, but...
    By tbloss001 in forum Electroplating Questions
    Last Post: 07-30-2003, 02:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
