Old 06-10-2002, 08:59 PM
edsel
Default Plating really small objects
I need to plate some stainless steel screws and studs.
These are pretty small objects. The screws are 1-72 and the studs are no bigger than 5/32"
I know that I would need to put a plate of nickel first right?
And then the final coat that I want brass.
Question is, how do I go about plating these small objects?. The instructions I recieved was to brush the wand over whatever I'm plating. I can't do that because of the size.
thanks
Old 06-13-2002, 07:10 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: Plug n plate kit for bathroom faucets ?
Sorry - been a busy few days.
You might have a problem plating Stainless Steel with a regular nickel kit. You'll probably need some of our Stainless Steel Activator. See http://www.caswellplating.com/accessmenu.htm
You will probably need to convert your Plug N Plate kit into a mini-dip plating system to plate those small items.
Do you have a copy of our plating manual?
Basically, you want to suspend the screws into the solution from a thin piece of copper wire. Hang the wire from a piece of copper pipe, sitting across the bottle of solution.
Connect the negative connection, your black alligator clip, to the copper pipe.
Place the plating wand in the bottle so that it is adjacent, but not touching, the suspended screw. Plug it in and you'll see results in 10 mins or so.
Test it by plating a small piece of copper, so you can easily see the results. When plating nickel onto steel, it's not easily apparent that a plate was deposited.
Have A Web Site?
Small Parts Plating in or around San Francisco, CA ckm Services Offered/Wanted 0 05-17-2005 05:18 PM
small Nickel plating job-any takers? y2khardtop Services Offered/Wanted 5 11-09-2004 11:33 AM
Nickel plating wanted Carmel N.Y. area (Small Job) cappi Services Offered/Wanted 0 05-06-2004 01:48 PM
Need Nickel Plating (small job) in NYC (could use mail) higginsjr Services Offered/Wanted 0 03-10-2004 10:14 AM
Plating many small items at the same time. pourdjee Electroplating Questions 3 11-07-2002 08:31 AM
