Old 07-18-2004, 08:43 AM
69t120 is an unknown quantity at this point
Default Follow up to Copy Cad problems
Hi all,
This is a follow up on a previous post. I was having problems with the copy cad kit not plating bright. While I was a little disappointed with the slowness of tech support’s response to my problem report, eventually I spoke to Mr. Caswell by phone. He offered several possible solutions, one of which seems to be the answer.
I had been running my cad solution at a minimum of 120 degrees. I had some problems with my heater thermostat running away and eventually the heater quit all together. From what I understand, higher temperatures produce a heaver, darker plate. I first lowered the temperature to 100 degrees and then stopped heating the solution all together (ambient temperature 90-95 degrees). This seems to have done the trick. I am now getting the bright plate that I was looking for.
I am still learning the subtleties, learning to read the plating and learning to tell when I need more brightener. I am still getting some dark speckles sometimes but at least I am making good progress.
Thanks to XK120DHC for the warning about Cheney clamps. Had I known about this earlier I probably would not have tried. However, by now I have successfully plated several and will just grit my teeth and press on. So far, I have only lost one. It was a terry’s clamp and the part that fell apart was the screw, the threads just fell off of it. I don’t know if it was the metal or just corrosion that weakened it to the point of it dissolving it the pickle#2.
Still “plugging” along, pun intended,
Art.
Old 09-06-2004, 09:31 AM
minitrailsteve
Default Copy Cad Problems and Should I try Copy Chrome
1. I also experienced the same problems with a dull plate from copy cad. Like others, I wasn't very impressed with the technical support that I received from Caswell (Canada).
Thanks to the message board, I will now try lowering the temperature, as suggested ... at least the Caswell customers are helpful !
2. If I don't end up with the finish I'm looking for, is copy chrome bullet proof or is it touch and go ? I re-plate small hardware (bolts, screws & nuts & washers) on Honda minibikes. The original plate looks like bright CAD but bright nickle would look just as nice or better. Any suggestions ?
triple chrome vs. nickel/chrome vs. copy chrome spectraflamed Electroplating Questions 4 01-21-2007 10:07 AM
Copy Chrome? / Temp? hefrod Electroplating Questions 4 08-18-2005 02:47 PM
Copy Cad kit - blackener and yellow cad durability problems Broke Electroplating Questions 11 01-09-2005 10:19 AM
copy chrome and aluminum problems jtagger19 Electroplating Questions 1 08-14-2004 06:15 AM
Problems with Copy Cad Matt Harwood Electroplating Questions 1 05-12-2003 09:29 PM
