+ Reply to Thread
Results 1 to 2 of 2
Thread: Differet copper plating questions, plus copy chrome/ nickel?
  1. #1
    Default Differet copper plating questions, plus copy chrome/ nickel?
    Can anyone explain why I would buy the flash copper plating tank instead of the regular copper plating system. I am going to use it to build up cast aluminum pieces. The regular copper plating system says that is what it is used for, but the flash copper doesn't say anything about building it up for repairing. But it really doesn't say much at all about what it is used for compared to the regular copper kit. Any help would be appreciated.
    Also, can I use copy chrome instead of nickel for the second plate in the triple chrome setup. Copy chrome is nickel with some cobalt added I believe, so I thought it might be alright to use. It would save me some money.
    thanks,
    Kenny
    Share with Facebook
  2. #2
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    in general the flash copper is an alkaline solution used to strike coat steel , and other base metals that would be attacked by the acid based copper..
    bill
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. copy chrome vs triple chrome plating
    By splbnd27 in forum Electroplating Questions
    Last Post: 06-21-2006, 07:35 AM
  2. Plating Problem grey finish from chrome plating
    By tshirah in forum Electroplating Questions
    Last Post: 08-13-2005, 12:08 AM
  3. Copy Chrome Start-up
    By Elitefisherman in forum Electroplating Questions
    Last Post: 04-18-2004, 04:24 AM
  4. Chrome, Nickel or copy chrome?
    By dwthomas in forum Electroplating Questions
    Last Post: 02-15-2003, 01:49 PM
  5. Copy Chrome Immersion system questions.
    By Great_Scott in forum Electroplating Questions
    Last Post: 03-20-2002, 05:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
