am doing some copper plating with a caswell kit,it is a 2
> gallon > > plastic bucket ,i tried it with a very small hr machine and it > did > > not work,maybee its broken?,i hooked it up to a 12 volt car > battery > > with one bulb on there and it worked ok but i would prefer a > plating > > machine that would work,i want to use it for gold plate and > nickel > > also,any one have any suggestions on a plating machine to > get.Thanks |
I assume by "a plating machine" you mean a dc power supply (or rectifier as it is called).
I know a lot of you try the "cheapo" let's try and save a buck method of getting the juice to do you plating, however, using a "real" power supply makes life so much easier and more efficient. Go to Caswell's site below: http://www.caswellplating.com/kits/rect.htm The 3 amp constant voltage/current model will work for smaller items and the price is just frigging fantastic! The 20 amp constant voltage/current model would be all you would ever need unless you were getting into chrome plating over 20 square inches in coverage. I have a power supply similar to the 20 amp (mentioned above) except it is a 10 amp supply (Instek brand---looks identical in appearance to Caswell's 20amp supply) and I paid $350.00 for it (2) years ago. Wish Caswell would have had the 20 amp unit when I bought mine! You just can't beat the price on Caswell's 20 amp unit. For $300.00 it is a great deal. Additionally, either of the constant voltage/current models Caswell sells will allow you to get ultra precision control over the plating. Spend the bucks on Caswell's units....you will be glad you did! GW |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 09:55 PM |
| Brass Plating Tank | agugliel75 | Electroplating Questions | 7 | 02-06-2004 08:50 AM |
| plating and size power? | chromo | Electroplating Questions | 7 | 01-18-2003 02:52 AM |
| Electroless Krome plating Q's | chcarver | Electroplating Questions | 1 | 10-10-2002 10:00 PM |
