Old 08-11-2004, 04:07 PM
Default copy chrome and aluminum problems
I'm trying to plate aluminum with a copy chrome kit but I'm having problems
it's coming out of the tank looking like sand paper once I dry it it starts to delaminate
I have tried all kinds of different amp settings and it's still happening
solution is not contaminated because everything else comes out great
(coopper pipes and metal)
the last thing I can think of is the zincate cuz is the only thing aluminum use that others don't .
is there any special way to zincate it ?
I just dip the part and after 2-3 minutes the part stops bubbling and I take it out and plate it.
any ideas
Old 08-14-2004, 06:15 AM
AresP
Buff or polish the aluminum surface to a bright shine. Wash with a mild detergent and do not dry. Apply Aluminum Cleaner by dipping or brushing it onto the work-piece. Note this is not an electroplating step.
Rinse with clean water and without delay dip or brush on the Zincate Solution, you should get a light gray coating on the aluminum.
If the coating is not even or has places without color. Cleaning and re-zincating is required. This is not an electroplating step.
To activate/clean the aluminium prior to zincating, some people use diluted lye
Maybe the problem is improperly cleaning/activating your aluminium surface before the zincate step.
Copy Chrome on engine parts and plastic, alot of can I's cgworth Copy Chrome Kit Customers Only 3 08-29-2005 12:38 PM
removing copy chrome from aluminum impactelectro Electroplating Questions 1 03-17-2004 12:49 PM
Removing the chrome surface from aluminum based auto trim jbashaw Metal Polishing Questions 6 10-01-2003 10:20 PM
Copy Chrome II on Pot Metal wbrown Plating Pot Metal 1 04-09-2003 08:15 AM
Plug N Plate Copy Chrome question Great_Scott Electroplating Questions 5 03-20-2002 05:53 PM
