+ Reply to Thread
Results 1 to 4 of 4
Thread: Acid copper
  1. #1
    Default Acid copper
    I am just staring out with lots to learn. I have a 15 gallon set up of flash copper, acid copper and nickel. I mixed the solutions according to the instructions. The pH of the acid copper is too low, 0.9, I understand it should be in the range of 1.0 - 2.0. Needless to say if I were to do it again I would have checked as I added the battery acid to achieve the correct pH. Being new I did not fully understand and I was just going by the instructions. So now I have this tank with a very acidic mixture and when I try to plate a part it comes out very course, almost as if it were all just lines of copper being deposited. The piece is 36 sq" I have the power supply set at 2.5A, as well as trying it at 3.0A. I flash copper plated it first and that worked great. Degreased, rinsed and in it went again to the acid copper tank. I have a pump circulating the solution as well as it is at 110 f Does any one have any suggestions? How can I raise the pH?
    Thanks
    Share with Facebook
  2. #2
    Join Date
    Feb 2003
    Location
    southeast
    Posts
    215
    if your flash copper is fine ,try plating in the nickel tank over the flash copper, then plate acid copper over the nickel to make sure exactly what the acid copper is doing before changing any phs.?
    bill
    Share with Facebook
  3. #3
    Caswell says to use ammonia to raise the PH. I am having the same trouble using the acid copper solution. My pieces come out rough and don't build up like they should. It puts on a thin layer of copper and then seems to quit. Any suggestion?
    Share with Facebook
  4. #4
    Default acid copper
    After many frustrating days of trying to get the copper to plate, I was informed by tech support that the number in the manual for setting the power supply is wrong. Tech support said it should be 1 amp for every 16 sq" not 10 - 30 as in the manual. I am using 16 now and it is great. So I think a little better prof reading would have saved me a lot of time. (and money). I would not worry about the PH.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. "Sandwiching" Acid Copper
    By AresP in forum Electroplating Questions
    Last Post: 08-27-2004, 08:19 PM
  2. filling small pits with acid copper
    By danderson in forum Electroplating Questions
    Last Post: 08-25-2004, 07:55 AM
  3. Acid copper plating problem! Attention Fibergeek
    By Gabourie in forum Electroplating Questions
    Last Post: 08-14-2004, 11:24 PM
  4. where do i get battery acid for my copper kit
    By plater12 in forum Electroplating Questions
    Last Post: 07-17-2004, 08:49 PM
  5. Strike Copper or Acid Copper over Nickel?
    By mdarr in forum Electroplating Questions
    Last Post: 07-13-2003, 01:53 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
