Old 09-13-2004, 12:41 PM
Gabourie
Default Nickel Plating long tube
Using an idea from the plating manual, I have fabricated a plating tank that is 46" long and 5" in dia. I made a shorter one to flash copper and acid copper plate a tube that is 42" long and 1" in dia. The solution is being circulated by a pump and draining back into the larger tank.
My question is: as I lower the tube into the tank do I need to increase the current to accommodate the larger area of part being submersed? IE). 1 amp per 17sq". The anode length is only 24". And will there be more nickel on the part that has been in longer?
I am trying to achieve a bright nickel plate.
Does anyone have any ideas?
I think by typing 1 amp per 17 sq" I just answered my own question
Old 10-12-2004, 08:02 PM
wop1969
LOL
if the part is being lowered slowly you will need to turn up the amps based on how much Sq Inch is in the tank or it will not plate at all
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 09:11 AM
Nickel bath inexplicably quits plating jackf Electroplating Questions 5 01-25-2005 09:55 PM
Differet copper plating questions, plus copy chrome/ nickel? krsimulis Electroplating Questions 1 07-26-2004 12:25 AM
boron plating on electroplated Nickel jackf Electroplating Questions 0 03-29-2004 01:41 AM
Need Nickel Plating (small job) in NYC (could use mail) higginsjr Services Offered/Wanted 0 03-10-2004 10:14 AM
