Connect with Facebook
Closed Thread
Old 10-01-2004, 08:12 PM
andnew
Default Doh! reverse polarity on a nickel run, now won't plate.
Hi all,
I pulled a stupid and hooked up reverse polarity on a nickel kit while trying to plate a piece of copper. This covered my nickel anodes with a copper plate.
I stripped off the copper from the anodes. But now my solution seems to be contaminated. Can anyone suggest if I need new solution, or would a high amp plate of a corrugated piece clear it?
Thanks,
Andy
Old 10-02-2004, 01:00 PM
wop1969
Check with caswell and see if it is safe to put the nickel anode into picle solution if you have some. I use coper wire for work holders and my pickel tank always strips the wire clean. I stress to check with caswell about chemical reaction first
Old 10-03-2004, 11:32 AM
48Buick
Yes.
What you are describing is called dummy plating. Dont go with high amps though. Use low amps and let it plate for 15 min. Then try a peice of copper and see how the nickel plate comes out.
Keep doing this until your nickel plating works as it should.
48Buick
Closed Thread
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 04:03 AM
Fixing partial nickel plate sross Electroplating Questions 3 10-31-2004 08:13 PM
gold plate over nickel - do I need to activate the nickel? tbloss001 Electroplating Questions 2 01-14-2004 10:57 PM
Plug n Plate lphurley Electroplating Questions 3 09-23-2003 01:15 AM
Should I Copper or Nickel plate? robert-a Electroplating Questions 1 06-29-2003 04:18 PM
