I am having trouble getting flash copper to stay on aluminum.
I degreased, zincated, then flash copper and it rubs of real easy or scrapes off like its not bonding to the metal. I am using a 4.5 gallon triple chrome setup with all the proper tank heaters filters and so on. I am using a aldonics CC CV 100 amp rectifier and I know I go the amps set right I have rechecked that many times over. IF there is anyone out there that has plated chrome on to aluminum successfully can you please post a detailed post about the steps and any other relevant info that you used to make this prosses work? Thanks Frustrated Added note: I have also tryed polish, degrease, zincate, nickle and polish, degrease, zincate, flash copper , acid copper. basicly I have tryed all forms of solution and technique order I could think of and none have worked so far? |
I found the trick (thanks to a little help from craig at caswell)
the main thing is to sand and polish the part to perfection before you even try to plate it so that once its plated you don't risk sanding back to the aluminum and starting all over again. Once you have sanded your arms right off you body |
How was the zincate involved in the process. I am getting blisters that peel off my parts also. I went through nicel and chrome but the part is not shiny. Any help would be great. I cant get the flash copper to stay on the part.
Wop1969
First off let me say that acid copper can go over nickel or flash copper, either can be used as a strike. There is no need to flash copper over nickel prior to acid copper. Ok let's get started. First sand and prep the part to get it close to the final stage as possible because alum is easier to work with (if you have deep gouges or pits, you will have to fill with solder later). Clean thuroughly, degrease and make sure you pass waterbreak. Depending on the alloy, you may have to desmut. Go directly into zincate for 5 to 30 sec, should be even dove grey,rinse, then strip zincate in pickle 3 (keep a close eye on it), rinse, back into zincate. This ensures a proper zincated surface. Rinse, (don't let it dry off at anytime Gtabadboy) go into flash copper LIVE with the amps up 50% more than what you calculated for the first 30 sec and roll power back down to the calculated value for the remaining 10 min. Now you can nickle for a sanding stop or go directly into acid copper (this is where you will fill with solder if needed and more acid copper). Gtabadboy, now you have to sand and buff the part to a mirror shine, you may have to do several 60 min cycles in the acid copper to get the part smooth, once your satisfied with the look, active copper with pickle 4, rinse,THEN go into the nickle live (buff again?) then chrome (go into chrome dead, and let it sit without power for 1 to 2 min.). Remember **** in, **** out. Motorcyle parts can be tough, there is more than just aluminum in their aluminum, some worse than others, you may have varying degrees of success. If that doesn't work, fling the part across the shop a couple of times. |
The alum. is hard to plate but you have to find that perfect spot on the amps in the flash copper. If you zincate then rinse and go into flash copper at a low amp you should do good and make sure your temp. is at 120 also and agitate the solution. I switched from cyniade to the flash and I am starting to like it. The acid copper at a high amp would give me trouble also so watch both copper baths. The pickle #4 helps but I can still plate without it but try different things and be patient.
| Flash Copper Problem | gwjohnso | Plating Pot Metal | 12 | 02-28-2007 12:41 AM |
| Does copper wire react with Zincated Aluminum?? | krsimulis | Electroplating Questions | 2 | 07-01-2004 09:51 PM |
| Strike Copper or Acid Copper over Nickel? | mdarr | Electroplating Questions | 2 | 07-13-2003 02:53 AM |
| Strike copper or bright copper after zincate? | mdarr | Electroplating Questions | 2 | 06-29-2003 03:23 PM |
