The Copy Chrome™ process is ideal for all your small items such as door handles, brackets, hinges, nuts & bolts, stamped steel covers, etc. It can be applied to:- steel, copper, brass, bronze, old nickel plate, and with the aid of Zincate Primer, aluminum.?
That came from caswells website and tat is all I could find so for now the answer is no. I will get a piece of cast iron and try to plate it in my triple chrome system and I can then give you a better answer. If i can get nickle or copper onto it then the answer would be yes. Ill post back A.S.A.P. on this matter |
I've done some cast iron. It takes the plate fine. I would tone down the acid pickle a bit however. Dilute it 50% vs. what you'd use for steel, copper, or brass. The concern is it might etch the cast iron a bit.
Also--if you have any problem with your cast iron and the nickel solutions, simply use Flash Copper first. Kind regards, Ken |
| Cast Iron ???? | fking962 | Electroplating Questions | 2 | 09-04-2005 01:52 AM |
| Anybody ever polished a cast iron engine block? | thesound | Metal Polishing Questions | 5 | 02-10-2005 10:31 AM |
| Prepping cast iron. | Stytooner | Powder Coating Questions | 3 | 08-04-2004 09:30 AM |
| Cast iron prep | ewmorritt | Metal Polishing Questions | 1 | 05-28-2003 12:31 AM |
| Chrome Plating Plastics and Die Cast Metals? | nunnc | Electroplating Questions | 1 | 05-21-2002 02:45 PM |
