Old 07-23-2002, 07:26 PM
wallyaction
Send a message via Yahoo to wallyaction
Default plating equipment
I have a motorcycle shop and I am thinking of do my own plating and I am trying to pick out a triple chroming kit that is just right for me. I was thinking of starting off small and I am wondering if the 4 gal triple plating kit is good for a beginner and for a repair shop, if not please let me know which kit is the best one for me. Also does the 4 gal kit comes with rectifiers.
Old 07-23-2002, 10:28 PM
mcaswell's Avatar
Caswell Inc Founder
Default Re: plating equipment
Yes, the 4 gallon kit is what I would recommend for starting a small shop, although it\'s certainly jumping in head first
The cautious approach would be to start off with a small kit, like the 1 gallon nickel plating kit. You read the manual, plate a few objects with nickel, get a feel for the whole process. Then you\'ll be more comfortable making a serious investment.
None of our kits come with rectifiers. The manual discusses several alternative power supplies and you should probably try one of these before spending $$ on a rectifier.
Have A Web Site?
Old 07-25-2002, 11:45 AM
Shevalik
I have the same idea. I have a two gallon kit, so I am one step ahead. I believe the best way, is to get started small and master the process before investing the money on a larger line. I have found that the main factor to consider in getting started is the actual power supply you will be using to plate with. A 25 amp power supply will allow you to do the copper and nickel plate on just about any thing on a bike, the chrome process requires significantly more power. With a 25 amp power supply, your biggest piece that you will be able to chrome would probably be a master cylinder or handle bar controls, bolts, maybe headlight bezels, etc.
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 09:11 AM
looking to sell all of my plating equipment bikerrandy Electroplating Questions 8 07-08-2005 04:31 PM
Nickel bath inexplicably quits plating jackf Electroplating Questions 5 01-25-2005 09:55 PM
plating and size power? chromo Electroplating Questions 7 01-18-2003 02:52 AM
Electroless Krome plating Q's chcarver Electroplating Questions 1 10-10-2002 10:00 PM
