Old 10-24-2004, 02:36 PM
sross
Default Flash nickel?
Caswell-
I just read that electroless nickel can be plated directly over electrolytic nickel. So.... would a nickel strike from the pnp kit be enough base to them put it in the electoless?
Thanks,
Seth
Old 11-14-2004, 11:50 AM
Moderator
Hello,
I noticed your post has been up awhile; not sure your question has been answered.
In my opinion, as a general rule, there is no substitute for tank plating a flash plate. It will be more even and will get into all the areas that you can't reach with a hand wand.
A lot depends on the base metal. If the electroless is not compatible with some base metal, then a nickel flash applied with a wand may leave too many voids for a tank plating in electroless later.
What is the base metal?
Kind regards,
Ken
Old 11-15-2004, 01:04 PM
sross
Gun steels of different types. I am going to do the barrel and frame as a unit. The cylinder and some other parts as individuals.
Seth
Old 11-15-2004, 06:14 PM
mcaswell's Avatar
Caswell Inc Founder
If you are plating steel, then there is no need to apply any 'flash' plate. Just go directly to EN.
Have A Web Site?
nickel copper flash kit keala Electroplating Questions 1 08-25-2005 09:30 AM
How to plate Nickel over old Nickel when steel shows through ASHENASH Electroplating Questions 3 04-22-2005 03:03 AM
Dealing with partially nickel plated steel AresP Electroplating Questions 3 08-19-2004 10:41 PM
Plug-n-Plating Nickel over Flash Copper JoeMig Plating Pot Metal 0 07-22-2004 12:13 PM
Chrome, Nickel or copy chrome? dwthomas Electroplating Questions 1 02-15-2003 01:49 PM
