Old 11-11-2004, 07:50 PM
allcarfan
Default Help with PLug n plate kit
I just received my chrome plug n plate kit.
I had to use it as soon as I got it...of course. So, i got an old brake dust shield in the garage. I polished a little spot on it with a 320 grit die grinder. Then i cleaned it. Then I wiped it with acetone....wiped it with a dry cloth.
I hooked in the wand, grounded the dust plate. I put a little of the solution in the cap of the bottle. wrapped the wand with some of the provided gauze....dipped it in the solution. I started rubbing the small, prepped spot....slowly at first....and I could hear some fizzing....but saw nothing. I decided to move the wand a little faster and press down...still....nothing. I let it dry...redipped the wand and started again....still....nothing. I decided that maybe if I buffed it, it would make a difference. I got my dremel and some never dull....made it nice and smooth. I polished another small area right next to it with my 320grit die grinder and didnt do anything else to it...I compared the two...they look exactly the same....
Am I doing something wrong?
Old 11-12-2004, 07:07 AM
mcaswell's Avatar
Caswell Inc Founder
Sometimes it is very difficult to see a difference on a white metal.
Try plating a piece of copper as a control. It should turn out a little smutty and grey and will need polishing. If it works on the copper, it's working on the steel.
Have A Web Site?
Old 11-14-2004, 11:27 AM
Moderator
Is the Plug n' Plate kit a chrome kit or copy chrome? I'm not sure you'll see much contrast on steel if you try the chrome component alone?! You'll have to lay down the nickel first, I imagine, for much to be visible.
Compared to steel, nickel will have a slightly yellowish cast. Then when you apply the chrome over the nickel, it will take on a slightly bluish tint.
Of course if it is copy chrome (or if you are plating with the nickel component of a chorme kit), then you should be able to see that pretty clearly on copper as Caswell said.
Kind regards,
Ken
Plug n Plate Gold over Sterling novenarosary Electroplating Questions 0 03-12-2004 10:00 PM
Plug n Plate lphurley Electroplating Questions 3 09-23-2003 12:15 AM
Plug N Plate Question carmelmike Electroplating Questions 1 03-20-2003 06:10 PM
Plug & Plate a Beltline?? ecoglio Electroplating Questions 1 03-05-2003 06:51 PM
Plug N Plate Copy Chrome question Great_Scott Electroplating Questions 5 03-20-2002 05:53 PM
