Jeff,
I made my own cabinet once and hooked up a five horse shop vac to it, put may arms in the gloves, flipped the switch with my foot and it had so much suction that I couldn't get my arms back out. I then switch to a peice of junk vacuum that had a hose attachment (someone threw it out), and it was much better. Give that a try, if it seems like your loosing media, stuff something in the hole until you get enough suction that you can see, but not loose media. Darrin |
I used a wall mounted Sears shop vac on my first small blast cabinet. The Sears unit was worn out in less than 1 month and was not covered under warranty.
I also used a Sears 5 HP vacuum but restricted the air flow by using a narrow connection pipe (1 1/4 inch). This worked fine for quite some time, but I needed to change the filters regularly. Try putting a foam filter at the outlet of the blast cabinet. This tends to catch most of the media before it goes downstream to the vacuum. My experience was with brown aluminum oxide which is very abrasive to metals (eg blower motor bearings!) Glass beads might not have such an affect; I don't know. A good 65scfm vacuum system can be had for about $120 from Cyclone, when you're ready. For me, I wish I would have bought it before trashing the vacuum cleaner--it would have broken pretty close to even. Ken |
I've jerry rigged my 40 # pot sprayer through the box as the suction shooters just don't supply enough cut power for the time invested for me, and 2 vacs: one a 3 hp shop vac, and a Eureka. With both going, shooting 30 mesh at 80 pounds, I can just barely see with a protected 300 watt light. After 2-4 minutes I stop and the field clears in 20 secons maybe and off I go again, making real progress and a great looking patina that takes powder coat wonderfully! VEM
| Question about media blasting. | berad001 | Metal Polishing Questions | 1 | 02-05-2005 12:29 AM |
| Media blasting?? | trsick | Powder Coating Questions | 4 | 02-02-2005 11:03 AM |
| Cleaning Oxidized Aluminum With Sand Blasting Media? | freematt | Other Metal Finishing Questions | 2 | 02-23-2004 03:22 AM |
| Blasting media for removing casting marks | gottago_joe | Metal Polishing Questions | 0 | 06-01-2003 07:15 PM |
| Best Blasting Media process for polishing? | tomg552001 | Metal Polishing Questions | 5 | 12-23-2002 03:22 PM |
