If I plate plastic...first i need to paint the surface with the conductive paint...then copper plating...and I want to ask do I need to nickel plate on the copper surface before copy chrome plate? If no, will the quality be better if I do so instead of just copy chrome on the copper surface?
Copy chrome over copper is fine. You only need a nickel plate underneath if you are plating real chrome plate.
A plated finish will last indefinitely, assuming it\'s in a no-wear environment and is taken care of.
You\'ll likely need to give it a light buff after plating to bring out the shine.
Sorry, I don\'t understand your question.
Sure, you can use anything, including a car battery or battery charger.
However, you do need a way to control the power. You can just hook up a car battery to the plating tank, as it is usually too much power to plate small items. There\'s a technique in our manual using lightbulbs that most people find easy to do.
I have got your Copy Chorme Kit and Copper Plating Kit, but there are some problems.
1. Is the heater completely immerse in to the solution? Or just immerse the glass tube into the solution? 2.Battery acid is the liquid then fill the car battery? 3. How the SP Degreaser work? And what does it for? |
This is all explained in the manual. Have you given it a good read yet? All of these questions you have asked can be answered from reading the manual.
You place the heater so the glass part is immersed, but the plastic part is not. Yes, battery acid is the stuff that goes in car batteries. SP Degreaser is used for degreasing, surprisingly enough. You heat it up and immerse parts in it. If you have other product support related questions, please post them to our technical support area (PRS) at http://www.caswellplating.com/support.htm
| triple chrome vs. nickel/chrome vs. copy chrome | spectraflamed | Electroplating Questions | 4 | 01-21-2007 11:07 AM |
| copy chrome vs triple chrome plating | splbnd27 | Electroplating Questions | 18 | 06-21-2006 08:35 AM |
| Copy chrome and resistance to rust, tarnish, dulling? | phunkmastakrez | Copy Chrome Kit Customers Only | 6 | 08-25-2005 10:13 AM |
| Copy Chrome Start-up | Elitefisherman | Electroplating Questions | 10 | 04-18-2004 05:24 AM |
