I have an aluminum radiator shell that I would like to nickel plate. It will need to have a couple of areas patched and deep pits and scratches filled first. The process that I have in mind is:
1 Patch the damaged areas using Techno-Weld. 2 Use Pit-Stop as a surface filler, like using body putty prior to painting a car body. Sand smooth such that only pits & scratches are filled. 3 Zincate & anode process nickel plating. Will this method work? Bill |
| Something for you die hard polishers out there to chew on | thesound | Metal Polishing Questions | 15 | 12-03-2007 01:16 PM |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 10:11 AM |
| Nickel bath inexplicably quits plating | jackf | Electroplating Questions | 5 | 01-25-2005 10:55 PM |
| Differet copper plating questions, plus copy chrome/ nickel? | krsimulis | Electroplating Questions | 1 | 07-26-2004 01:25 AM |
| boron plating on electroplated Nickel | jackf | Electroplating Questions | 0 | 03-29-2004 02:41 AM |
