Bill H;
Two questions about Nickel over brass.. Electroclean in what?? SP Degreaser?? What amp level & how long? Activate in what? I've been told to use a mild 3% solution of Sulfuric Acid (H2SO4). One of the problems I having with that involves the math.. "Battery Acid" is stated to be 35%, but most "seasoned" platers I've talked to say it's closer to 25%.. And when I try to figure 3% of 25% I get a ratio of 8.34 parts H20 to 1 part Battery Acid which doesn't "look like" a 3% mix.. The part I need to plate is a fifty-two year old bulb holder/reflector for a British Sports Car's Reverse Light, which has been stripped of it original finish (claimed to be "Butler Chrome") and polished to a beautiful mirror shine, inside and out. Any, and all, clarification gratefully appreciated. Last edited by XK120DHC; 11-25-2005 at 03:55 AM. |
You stated it was 'Butler Chrome', and I've never heard of such a thing. Are you sure they don't mean 'Butler Nickel"?
Have y'all ever heard of this? Also, would you like to address the primary issue I asked Bill about?? "Electroclean in what?? SP Degreaser?? What amp level & how long? Activate in what? I've been told to use a mild 3% solution of Sulfuric Acid (H2SO4). One of the problems I having with that involves the math.. "Battery Acid" is stated to be 35%, but most "seasoned" platers I've talked to say it's closer to 25%.. And when I try to figure 3% of 25% I get a ratio of 8.34 parts H20 to 1 part Battery Acid which doesn't "look like" a 3% mix.." |
| Nickle "Plug-N-Plate" question HELP!! | pyro1711 | Electroplating Questions | 1 | 08-03-2004 09:29 PM |
| Brass Plating Tank | agugliel75 | Electroplating Questions | 7 | 02-06-2004 08:50 AM |
| Clearcoating brass after polishing | skipmac | Metal Polishing Questions | 1 | 10-04-2003 08:58 AM |
| Brass Weathered Finish Look/Antique Brass | agugliel75 | Metal Polishing Questions | 2 | 06-21-2003 08:09 AM |
| Uh-oh, where'd the brass go? | jtowens | Metal Polishing Questions | 1 | 02-07-2003 02:17 PM |
