I just purchased a Caswell Nickel plug and plate kit. How large of parts can I do with this? I want to plate a Desert Eagle pistol. Will this kit do it, or will I need a larger kit. If so, what do you recommend. Also, What is the best way to prep the metal? It is blued steel. I am a powder coater, and this is my first plating experiment. Thanks for the help.
Kris |
The PnP Nickel will work great, but a tank setup would be ideal for a part the size you describe.
The most important part of plating is in the preparation. You'll want to have bare, clean steel before beginning the plating process. Ken |
| How to plate Nickel over old Nickel when steel shows through | ASHENASH | Electroplating Questions | 3 | 04-22-2005 04:03 AM |
| Nickel Replate: acid etch still needed after mechanical stri | xiphmont | Electroplating Questions | 4 | 05-14-2003 12:57 AM |
| Chrome, Nickel or copy chrome? | dwthomas | Electroplating Questions | 1 | 02-15-2003 02:49 PM |
