+ Reply to Thread
Results 1 to 4 of 4
Thread: Remove chrome plating from plastic
  1. #1
    Default Remove chrome plating from plastic
    How can I remove chrome plating from automotive plastic parts??
    Will Muratic acid or acetic acid eat away the plastic I need something safe to use on the underlying part.
    Thanks for the help.
    Share with Facebook
  2. #2
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,794
    Default Re: Remove chrome plating from plastic
    You can very carefully reverse plate the chrome off, using an acid pickle. You should be able to remove the chrome layer down to the nickel underneath without harming the plastic.
    It\'s unlikely that a bit of acid on the plastic will harm it anyway....after all the acid probably came in a plastic container, right?
    You can also buff it off.
    Have A Web Site?
    Share with Facebook
  3. #3
    Where can one purchase or make this \"acid pickle\"??
    When the chrome is removed what can be done to remove the nickel that is left on? Buff it off from there maybe?
    thanks
    Share with Facebook
  4. #4
    Join Date
    Nov 2001
    Location
    Lyons, NY USA
    Posts
    1,794
    There\'s a formula in our plating manual. http://www.caswellplating.com/complete.htm It\'s mostly battery acid.
    If you want to remove the nickel also, there is another pickle you can use, or you can buff it off.
    Have A Web Site?
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. copy chrome vs triple chrome plating
    By splbnd27 in forum Electroplating Questions
    Last Post: 06-21-2006, 07:35 AM
  2. chrome plating plastic dash QUESTION
    By gtolovedaddy in forum Electroplating Questions
    Last Post: 08-25-2004, 06:11 PM
  3. Chrome plating plastic services needed.
    By qwik3r in forum Services Offered/Wanted
    Last Post: 02-08-2004, 03:45 PM
  4. chrome plating on plastic
    By jean in forum Services Offered/Wanted
    Last Post: 04-20-2003, 08:28 PM
  5. Plastic Chrome Plating
    By mr.wagon in forum Electroplating Questions
    Last Post: 08-06-2002, 08:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
