Old 01-14-2005, 02:43 PM
clydes is an unknown quantity at this point
Default tank heaters
has any one had any luck with the clepco heaters? hanging from a tank bar in larger tanks. process technoligys will build custom built heaters for your tanks at a comparable price with controls out side of the tank to avoid wetting out due to condensation. its worth a look. any feed back on this issue is welcome. clydes
Old 01-15-2005, 10:24 AM
Moderator
I'm not sure many of the folks here have your tank volume. I believe Caswell sells a new heater and controller combo for 15 gallon tanks with an outside electronic controller?
No reason you couldn't use one of Caswell's in your setup. Chances are it would be more cost effective than a custom design.
Alternatively you could probably do the same thing with an off the shelf used temperature controller module and a Caswell heater. You could put the thermocouple in a small glass tube and seal it with RTV. Then you could immerse it in your tank safely. If I go to a larger tank (5 gallons max for me!) this is what I plan to do.
I appreciate that temperature control is somewhat more important than it might seem at first. The resistivity of the solution is very strongly a function of temperature. That's why when people start referencing "volts" between anode and cathode, it is meaningless without knowing first what the tank temperature is.
Ken.
Old 01-15-2005, 12:36 PM
Ken,
You do have a working knowledge of Ohm's Law. Its no surprise that you are a successful plater.
Now, if we could only get the rest to stop resisting this (no pun intended) our jobs would be considerably easier.
BTW, its equally meaningless to talk voltage without first knowing the tank volume, anode & cathode surface areas, and anode/ cathode spacing.
All of this applies to anodizing too.
Old 01-15-2005, 01:30 PM
Moderator
Thanks for your complimentary words.
Absolutely. That's why one person's successful plating voltage is too often another person's burnt plate.
Better safe than sorry--stick with constant current.
Do you use titanium baskets with nickel rounds or s-rounds, or do you just stick with the plates?
Ken
Old 01-15-2005, 07:20 PM
Neither. I deal with the anodizing forum. As you've noticed I field some of the electrical questions over here.
Both anodizing and electroplating are governed by Faraday's Law, that means the math and physics are the same, just the numbers are different.
Mike wants me to start messing with plating, I will eventually. This would consist of taking the formulas and techniques guys like you use, and reducing them to the governing math. All verified by actual controlled plating experiments of course. Why? It will make electroplating as predictable and sure as we made anodizing, works every time (if you follow the directions). Mike and the accomplished platers here would be instrumental in this, I'll need to start by picking your collective brain.
Old 01-16-2005, 09:26 AM
Moderator
Glad to help. My profession is computer-based automated measurement. Bet we could set up some interesting experiments.
Ken
Old 01-16-2005, 08:07 PM
jmerson
Default formulas
O.K. Geek,
I'm refering to the post talking about formulas for plating. I'm using the 6 gallon tanks but sometimes there may only be 3 or 3.5 or maybe 4.5 gallons of liquid in a tank. I use the anodes that came with the Triple Chrome Kit and try to heat to the temperature listed in the Caswell's Plating manual. I try to plate HOT and I'm using an 18 volt, 100 amp CC plating rectifier. Ken has been helping me in the past and also George. They have both been very helpfull. Your comment about everything being relative, as far as size of anodes, temperature of liquid, size of plated piece, etc, makes a lot of sense to me and I would be interested in trying out a formula if you come up with one.
  #8 (permalink)
Old 01-17-2005, 01:23 PM
that glass jar incloser sounds like a idea worth looking into. i was wondering would a hot water heater element work for that? what we have ordered now is a (l) shaped heater to heat from the bottem up with a 90 degree angle on the top end out side the tank. this will i hope stop the condensation in the top of the heaters and keep the sand dry. but the idea of the glass jar sounds a whole lot cheaper. what would you recommend for sealing the inlet to the jar? thanks clydes
  #9 (permalink)
Old 01-17-2005, 01:44 PM
Moderator
I'm not sure exactly what you mean, but I never thought of using a hot water heating element. The trick with this kind of thing is getting good thermal conductivity to the solution. But you don't want any foreign metal like regular steel or copper in contact with the solution, since it could corrode and contaminate it. That's why people make titanium and quartz heaters. They don't react with the solutions.
I was thinking about a simple temperature sensor (thermocouple) being inserted into a glass pipette which could then be filled with water and sealed with RTV. I'm not sure if that idea would work with a heating element, since the element would try to boil the water around it and that would be a problem.
Ken
  #10 (permalink)
Old 01-17-2005, 03:57 PM
i see what you are saying . well i have the titanium heaters coming from process tech. hope they solve my problem. we have burnt out 6 1000 wat titaniums so far by way of condensation over the tank with the lids . getting kinda expensive. the ones we ordered are 305 a peice so with any luck we will solve this problem. thanks for the feed back. clydes
using aluminum as a cathode scocklin Anodizing Questions 19 03-31-2007 12:18 AM
Need opinions on my next tank. jtsuttle Anodizing Questions 4 03-29-2004 12:32 PM
Tank Heating Questions. meganine Anodizing Questions 1 08-03-2003 03:20 PM
Heaters for a 45 gallon tank jsnow2060 Electroplating Questions 2 01-26-2003 07:47 AM
