Ok I have started the process of plating a rose with gold
Here is what I have does so far, Created a bath to dipped the rose in sealent ![]() Applied two coats for 30 minutes ![]() Hung the rose to dry and painted the rose with silvraspray ![]() ![]() Now my question is, do I contunue with a copper acid plate? Or should I use something else? Any advice? |
The longer you can cure the paint the better. It prevents the paint from failing in the acid solution. Maybe go as long as you can watching carefully for cracks. The paint MUST thoroughly cure before plating it, or it will not hold up.
Ken |
Maybe I will try to dry the rose on silica gel or borax before I coat and paint. But im not sure how that will make the rose look afterwords
In the meantime, I am still getting the tanks ready ![]() Battery ![]() How should reduce the current for something as small as a rose? |
Go to Radio Shack and buy a 39 ohm 5 watt resistor and put it in series with your car battery and the anode. That will give you about 300mA which should be about right for something like a rose (assuming your battery is 12 volts).
The resistor will get HOT so keep it away from anything flammable. You can also get two 22 ohm 5 watt resistors and put them in series. It will give you about 270mA which should be close enough. The resistors will also stay cooler. Ken |
Ok, I moved it into my garage becuase it remined me of the days I had to go to the gas chamber when I was in the millitary. I have a fan and I leave the door open.
What if I use flash copper before the bright acid copper. Will I still need to let the paint cure for 7 days. |
| trouble plating with 18K fast gold solution | didierphmartin | Electroplating Questions | 2 | 05-06-2008 03:51 PM |
| how to create a satin finish on gold plated material | didierphmartin | Electroplating Questions | 3 | 11-15-2004 03:00 PM |
| How about Gold on Gold ? | Ra | Electroplating Questions | 5 | 10-12-2004 08:47 PM |
| Need 3 inch scorpion gold plated for movie | falworth | Services Offered/Wanted | 0 | 08-03-2004 11:32 AM |
| gold plating on brass | jomida | Electroplating Questions | 5 | 02-23-2003 11:34 AM |
