+ Reply to Thread
Results 1 to 3 of 3
Thread: plating M/C brake rotors
  1. #1
    Default plating M/C brake rotors
    What plating would be best for use on motorcycle disc brake rotors?
    durability is the big factor,appearance is secondary. I own several vintage British bikes and I am looking for a durable, clean finish.
    Share with Facebook
  2. #2
    Join Date
    Jul 2003
    Posts
    537
    I had a 650cc BSA twin in college, so I know what motorcycle disc brake rotors are. I ultimately replaced it with a 903cc 4 cyl. 4 stroke Kawasaki Z1 "road rocket", now that thing was a machine, but I degress.
    We have some people here who are quite experienced in restoring vintage motorcycles, including plating for the same. I have a question; considering how disc brakes work, is any kind plating suitable for anything other than a show bike? One that sees little actual road use?
    Motorcycle platers to the rescue.
    Share with Facebook
  3. #3
    Join Date
    Nov 2004
    Location
    close to Austin, Texas
    Posts
    1,283
    I am a master mechanic that has ridden and been around bikes for years. Do you intend to ride this bike? Not to say there is not a plating for brake rotors but I have not run across one yet. Due to the high heat generated and the abrasiveness of disc pads a plating would not hold up to much driving. Not to mention if a resurface was needed to correct warpage or parallelism. Most rotors I have dealt with had the center area painted or plated but the braking surface was ground. I don't know if this helps but good luck. I am restoring a 78 KZ1000 Police now. Lots of fun but lots of work.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Gold Plating and Nickel plating
    By tzmandevil in forum Electroplating Questions
    Last Post: 09-16-2005, 09:11 AM
  2. Coating Brake Rotors
    By rickanderson53 in forum Other Metal Finishing Questions
    Last Post: 08-18-2005, 11:15 PM
  3. Nickle Plating Disc Rotors
    By 93BlackFD in forum Electroplating Questions
    Last Post: 12-23-2003, 01:46 PM
  4. Plating antique Brake Cylinders
    By firepower in forum Electroplating Questions
    Last Post: 03-11-2003, 12:42 AM
  5. plating and size power?
    By chromo in forum Electroplating Questions
    Last Post: 01-18-2003, 02:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
