Old 02-23-2005, 02:02 AM
gsw3 is on a distinguished road
Default Removing Tin Plating
I need to strip off the tin plating of some very small beryllium contacts so I can gold plate them. Only have a dozen to do.
I know you can use nitric/hydrofluoric acid; however, I'm sure no company will sell me the stuff.
Anyone have any alternative ideas?
These are too small to beadblast or hand strip (sand/buff).
Thanks.
George W.
Old 05-05-2005, 10:25 AM
bdjacobs
I restore tin-plate track for model trains. The rails on the track are more dense then your contacts so care needs to be taken. I use a masons form of HCL for my rail (because the rail I restore is also rusty). Masons use it to remove excess cement from laying brick. I would however suggest a product called Poly-Zag (a calcium deposit remover for toilet bowls). This has worked on my rail with no rust but the original finish was too far gone to be of value.
Old 05-06-2005, 10:16 PM
Thanks for the info.
I will give it a try.
George W.
Removing Nickel Plating drdarvocet Electroplating Questions 8 11-28-2008 02:22 PM
Removing copper plating.......Help! Coltsaa Electroplating Questions 8 11-04-2004 12:34 AM
Removing copper plating? Help...... Coltsaa Other Metal Finishing Questions 0 10-11-2004 09:58 PM
Removing old plating cshu Electroplating Questions 1 01-26-2003 02:30 AM
Removing old plating model_t Electroplating Questions 1 12-16-2002 11:02 PM
