Old 02-27-2005, 12:41 AM
Unix3000
Default Stainless steel plating tank
Does anyone know if plating can be done in a stainless steel tank?
Old 02-27-2005, 12:00 PM
Moderator
From my own experience and research, I know the flash copper does ok with 316 stainless anodes. In fact, you can plate all day with 316 stainless anodes, at least until the solution depletes of copper! So as long as it's 316 stainless, and you're using flash copper, I'd say go for it.
I am not sure about the acid copper mix, or the nickel. Anyone else have any comments? I know that in general 316 is one of the more chemical resistant of all the stainless alloys.
One more bit of advice: If you're not sure what kind of stainless alloy your tanks are made of, then play it safe and DON"T use stainless tanks.
Ken
Old 02-27-2005, 01:25 PM
Unix3000
I know you do the same with gold. I just have like 1000.... 18qt stainless pots left over from my other business that I just through away. Just though I would try to put them to use.
Old 02-27-2005, 02:27 PM
Moderator
In the plating process, there are a lot of steps other than the plating. There's degreasing, final cleaning, multiple rinses, etc. I'm sure those pots would be fine for these applications.
Ken
Chrome on stainless steel Fick Other Metal Finishing Questions 3 07-05-2005 12:27 PM
Copper plating on stainless steel 316L strip/sheet slee36 Services Offered/Wanted 0 03-31-2004 12:46 PM
Brass Plating Tank agugliel75 Electroplating Questions 7 02-06-2004 08:50 AM
plating tank setup confusion fxstcguy98 Electroplating Questions 5 01-28-2004 10:26 PM
Chrome Plating Stainless Steel: rabiddog22 Electroplating Questions 1 11-23-2002 05:04 PM
