I\'m having a few prototype printed circuit boards made, and I\'d like to gold plate the edge contacts myself - the PCB people charge a way-high setup fee for the service.
So, I figure I can nikel plate and then gold plate with your Plug N Plate method. But...I don\'t know if I can get the edge contacts masked, ie, left just plain copper - it may be that they will have to be tin plated along with the rest of the board. If that is so, can I nickel plate and then gold plate over the tin plate, or can I just gold plate the tin without nickel (too soft?), or should I really insist that the contacts I want to plate be left plain copper. The other question is whether I need to buy two plug n plate kits - one for nickel and one for gold - or can I just buy one gold kit, and a bottle of nickel solution? Thanks |
You can mask them yourself using our Mask-It solution - http://www.caswellplating.com/maskit.htm
or you could nickel, then gold plate over the tin plate. You can buy one kit, then a bottle of the other solution. The rest of the hardware is the same.
I got not so good results going over the tin/solder plate on my pcbs. I tried a number of strip methods (mechanical) and none really worked well enough. I found that nitric acid diluted with a bit of 12% hydrogen peroxide applied with a Q tip worked well for this. Then nickel, then gold, and it's as good as the pros can do it.
| gold plating solution gone bad?????? anyone from there ?? | clocktools | Electroplating Questions | 2 | 08-21-2008 06:44 PM |
| Question on gold plating | oldtoys1961 | Electroplating Questions | 4 | 05-07-2008 10:41 PM |
| Gold Plating and Nickel plating | tzmandevil | Electroplating Questions | 2 | 09-16-2005 09:11 AM |
| last step: finishing with wax on gold plating. Which one? | didierphmartin | Metal Polishing Questions | 1 | 10-29-2004 02:11 AM |
| gold plating on brass | jomida | Electroplating Questions | 5 | 02-23-2003 10:34 AM |
