Old 04-03-2005, 09:53 PM
Tim1hd
Default Mixing the pickle Baths
When mixing a acid bath. Is the amount of acid used measured by weight or fluid oz.?
Thanks Tim
Old 05-10-2005, 04:46 AM
etcc
Send a message via MSN to etcc
Default ACID IN COPPER PLATING BATH
Hi Tim...
For optimim results...Sulphuric Acid is used as follows...Per Gallon of Acid Copper Plating Bath Solution...
7.5 Ounces by WEIGHT...or...
4.1 ounces FLUID.
- etcc
"1,200 Year Old Highlander Immortal"
Old 05-10-2005, 07:42 AM
Tim1hd
Thanks for your help. I had forgot about this post.
Tim
Old 05-10-2005, 12:48 PM
etcc
Default Hmmm :-)
You're welcome Tim...it's IMPORTANT to know that difference.
Also...be sure to add the Acid to the water...NEVER water to acid...and stir well while slowly pouring it in...avoid splashes.
Which part of Ohio are you from?
I wish you great success in your plating and all you do.
- etcc
Old 05-10-2005, 05:02 PM
Tim1hd
I'm from North Canton. I started using Caswell's Copy Chrome kit first and then I moved on to Acid Copper. Right now I'm having great results so I don't plan on moving on to Triple Chroming anytime soon. Thanks again for your help.
Tim
MIXING POWDERS turch Powder Coating Questions 7 12-01-2004 10:00 PM
Dye mixing and fluorescent colors sgunn911 Anodizing Questions 17 10-18-2004 01:11 PM
pickle #4 fxstcguy98 Electroplating Questions 0 02-15-2004 11:01 PM
Pickle #4? mdarr Electroplating Questions 1 07-24-2003 02:17 PM
Can you electro strip chrome with pickle #3? tbloss001 Electroplating Questions 3 06-06-2003 09:36 AM
