+ Reply to Thread
Results 1 to 3 of 3
Thread: Quadrajet/Holley Amperage n other questions
  1. #1
    Default Quadrajet/Holley Amperage n other questions
    Hello, I'm unemployed...yeah its Buffalo n.y.
    I'm thinking I can make some money plating.
    I have a battery acid bath with dual fishtank heaters, dual air pumps for large bubbles, 10amp 6/12 volt battery charger and homemade rheostat.
    It is impossible to find out how many square inches the carburetor is. What should I start out at??
    Also, i'm a little confused.
    I want the bodies to be DULL yellow/goldish..... and the linkages to be BRIGHT yellow.... How do I achieve this....
    Does the brightener do this.... or is it a dye?? or both..... and do I add the die to the battery acid solution??
    I do have the manual... but would like to know for sure....
    By the way... I am ordering my zinc anodes and any other dyes through Caswell.
    I used mulfuric (spelling?) acid to remove the old zinc.. and rust...and then sanded and buffed to a mirror finish.....
    What a pain.. took hours of work to get in tight spaces.... I like in an apartment.. and have no room for a compressor...
    Are there any alternatives to a sand blaster.... I was in A.C Moore the other day... and noticed these aerosol sand blasting kits... for glass etching... only thing is ... its just a regular paint can size and costs 10 dollars..
    Any help or tips would be greatly appreciated...
    I'm getting nervous about my first projects.... and mostly nervous about an even finish on the carburetors...
    Thank you...
    Rob...
    You can cotact me through email also.. RCLSolutions@Hotmail.com
    Share with Facebook
  2. #2
    dull and shiney finishes are also dependant of finish going in. Try not polishing parts but rather going for a satin finish before plating.
    If your talking about actual colour depth or hue I am afraid thats beyond me, hopefully someone else will volunteer that advice.
    Share with Facebook
  3. #3
    Join Date
    Dec 2003
    Posts
    201
    First off, I'm pretty sure that carbs are cadmium plated not zinc (someone will correct me if I'm wrong). I can't answer all your questions because I'm not familiar with zinc and how it is dyed to look yellow. To figure the surface area of the carb. break it down into simpler shapes such as cylinders, cubes...ect., and figure the sq in from that. Don't worry about all the little tiny surfaces, at 1Amp per 15sq in of surface, (if zinc is the same A/sqin as copper), being off in your calc by 3 or 4 sqin is no big deal. I doubt if you can regulate the power that closely. I have never heard of sandblast in a can. I use a homemade booth with a 5hp comp and it took me 2 hours to blast 24sqin part completely, at that rate it would cost more to buy the cans than a whole blast cabinet.
    As far as doing this in your apt., better not be too attached to the deposit.
    One other thing, Buffalo sucks, I lived there for 5 years, hated every min. of it. Good luck
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Some newbie questions...
    By kiwijetpilot in forum Anodizing Questions
    Last Post: 03-12-2005, 08:18 PM
  2. A few newbe questions
    By thestormfamily in forum Electroplating Questions
    Last Post: 06-30-2004, 08:54 AM
  3. A few polishing questions
    By scimitartoo in forum Metal Polishing Questions
    Last Post: 02-10-2003, 02:34 PM
  4. a bunch of questions
    By spectraflamed in forum Electroplating Questions
    Last Post: 04-04-2002, 11:53 PM
  5. Copy Chrome Immersion system questions.
    By Great_Scott in forum Electroplating Questions
    Last Post: 03-20-2002, 05:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
