Old 05-18-2005, 12:12 AM
Coltsaa
Default zincate on aluminum
This is my first try at plating aluminum with bright nickel (electro). Ordered Zincate solution and mixed according to the manual. Waterbreak showed fine. Question: Should the zincate solution dry completely before going into the nickel bath? Or should I rinse with distilled water before going in to rinse off the excess zincate?
The part starts reacting immediately to the zincate so I left it in about 30 sec. This part was mirror polished when it went in and came out of the zincate a dull grey. Will I still get a bright finish when nickeled? Any advice would be greatly appreciated.
Old 05-18-2005, 11:37 AM
After passing water break, go directly into zincate if it begins to fizz, leave it in for only about 10 to 15 sec after the fizzing starts. The uniform dull grey color is normal. Rinse well and go immediately into the strike bath (flash copper or nickle) and go into the bath with the power on at about .13amps/sqin for 30 sec to 60 sec and then drop the amps back to .06amps/sqin for rest of the strike cycle (about 10 min). The bath will dissolve the zincate and if you have brighteners (nickle) in the bath, it should come out shiny. If you plan on doing a lot of alum., you should consider using flash copper and buffing afterwards (and before), because over time, the zinc will contaminate your nickle bath. Hope this helps.
Darrin
Old 05-20-2005, 10:09 PM
Coltsaa
Darin, thanks a bunch for the info! I think I'm on the right track now. I was also wondering if the zinc would contaminate. Probably will order a small nickel kit just for aluminum. I'll post when I get results. Thanks!
Old 02-14-2008, 01:49 PM
ekirkwood is on a distinguished road
Default Re: zincate on aluminum
thanks, i needed that info, too. elizabeth
Something for you die hard polishers out there to chew on thesound Metal Polishing Questions 15 12-03-2007 12:16 PM
using aluminum as a cathode scocklin Anodizing Questions 19 03-31-2007 12:18 AM
Do you have to use flash copper to plate aluminum krsimulis Electroplating Questions 1 07-27-2004 01:32 PM
pot metal or aluminum neil Plating Pot Metal 2 07-07-2003 11:52 AM
HELP! White haze when degreasing polished aluminum! davidh90046 Metal Polishing Questions 2 10-15-2002 01:19 PM
