Connect with Facebook
Closed Thread
Old 05-26-2005, 11:38 AM
gtabadboy
Default Keep getting blisters in flash copper plating...HELP
I am new at this. I sanded and prepped the part. Cleaned it in sp degreaser then distilled water. Then I zincated the aluminum part...let it drip dry then went into the flash copper.
After plating there are small blisters that I can pop and peel. Why is this happening. Also after nickel plating the flash copper it is not shiny. When I did the practice copper pieces in the nickel it looked like chrome. I just cant get past the flash copper stage. All the parts that I am doing are aluminum.
Old 06-18-2005, 07:37 AM
fly fly is offline
Make sure you don't have your amps to high and your temp. to low. After you flash copper go into your acid copper and then polish before you nickle.
Old 11-14-2005, 10:15 PM
moto-chrome is on a distinguished road
Unhappy Re: Keep getting blisters in flash copper plating...HELP
I have been fighting this same problem for weeks. If I can figure it out you'll be the first to know.
Old 11-15-2005, 12:57 AM
smokeycity
Default Re: Keep getting blisters in flash copper plating...HELP
That Is Not Your Problem Your Problem Is Nickle Strike You Must Nickle Strike After You Zinc. Drip Dry. Always Dip Part Into Distilled Water Befor Going Into Another Bucket
Old 11-15-2005, 11:39 AM
Alum can be a pain. Try this, zincate the part, rinse, strip zincate in nitric or sulfuric/water and zincate again. Don't drip dry the part, rinse immediatly after zincate and go into the flash copper "live" (power on). For the first 30 seconds or so, have the amps higher than what you calculated. This will make sure that the copper gets on before the part can oxidize (that's what the zincate is for). Too many amps and you will burn the plate, not enough and it may blister, you have to play with that a little. After the first 30sec, roll the amps back down to the calculated value for the rest of the cycle. Flash copper is always dull, you have to polish it before going into the nickle. Some cast alum will outgas and cause blisters no matter how much you try. Good luck man. Don't pull all your hair out, you will need a bunch of it if you try potmetal.
Old 11-16-2005, 11:11 AM
Wink Re: Keep getting blisters in flash copper plating...HELP
gtabadboy,
I found a procedure in this forum which worked first time I tried it. It looks like Voltage and amperage are extemely important. I was so happy I immediately called Caswell and bought a controler. You can find the procedure by clicking on SEarch This Forum and enter the keyword dishwashing. You will find a thread called Flash Copper initiated by Fly and a response by SRT Mike. My hat off to Mike who wrote a precise procedure which works. Note: one difference, I zincate, let dry 1 min then dip in warm water 5 sec before putting in the Flash Copper tank to avoid the thick ugly layer of Zinc.
Old 11-16-2005, 11:56 AM
mcaswell's Avatar
Caswell Inc Founder
This is the post: flash copper
Have A Web Site?
  #8 (permalink)
Old 11-17-2005, 09:19 PM
fly fly is offline
The instructions realy work, SRT Mike did a good job on describing the steps. Give it a try and let us know how you did.
Closed Thread
Flash Copper Problem gwjohnso Plating Pot Metal 12 02-28-2007 12:41 AM
flash copper on pot metal newview Electroplating Questions 2 11-18-2005 08:14 PM
Differet copper plating questions, plus copy chrome/ nickel? krsimulis Electroplating Questions 1 07-26-2004 01:25 AM
Newbie ? on copychome and flash copper? KevinW Plating Pot Metal 3 11-08-2002 01:49 PM
