Old 06-02-2005, 05:34 PM
albie
Default need help with my new plug n plate silver kit
Hello guys i have a question. im plating some small copper pieces with silver to try to lower there resistance some.. i used the dip method with the wand supplied and the 1.7 ps. the problem is that as soon as i dipped the parts they turn a nice silver so i let them sit in the solution for about 1 min which turns the parts a dull gray. after words i polish the parts but it seems the base copper shows through in areas.. to prepare these copper pieces they were cleaned and polished to a high shine then degreased with lacquer thinner and dried throughly and i use rubber gloves throughout.. is the 1 min submersion not enough time? i didnt heat up the solution will that help.... thanks for the help. albie niziolek
Old 06-05-2005, 12:28 PM
mcaswell's Avatar
Caswell Inc Founder
Increase your immersion time for a thicker silver plate which will withstand the buffing process.
Have A Web Site?
Old 06-05-2005, 03:24 PM
albie
i will try that .. what i have been doing is dipping the part for 10 sec.then taking it out for a few then re dipping for 10 sec.. i do this 3-5 times and i havent gotten any black smut at all this way...
also when do i know its time to buy new solution or a new annode?
exceltent product.. albie
Old 06-08-2005, 10:35 PM
Moderator
I have to wonder if air agitation would help. Have you tried it?
Ken
Old 07-11-2005, 07:13 AM
topspinner
I've found you really have to watch the polishing after the plating when using a mechanical polishing system. I've pulled plating off even with a non-cutting compound. Have you tried hand polishing?
Plug n Plate Gold over Sterling novenarosary Electroplating Questions 0 03-12-2004 11:00 PM
Plug n Plate lphurley Electroplating Questions 3 09-23-2003 01:15 AM
Silver polish on 24k gold plate?? chromo Electroplating Questions 3 04-07-2003 06:14 AM
Plug N Plate Question carmelmike Electroplating Questions 1 03-20-2003 07:10 PM
Plug N Plate Copy Chrome question Great_Scott Electroplating Questions 5 03-20-2002 06:53 PM
