+ Reply to Thread
Results 1 to 3 of 3
Thread: Filling pits in steel in preparation for nickel plating
  1. #1
    Default Filling pits in steel in preparation for nickel plating
    I want to nickel plate some old steel parts that are pitted. Is there a filler I can use that will allow me to nickel plate over it? I don't want to use a zinc base substance because I want to avoid copper plating first (this item never had a copper layer and I want to restore it).
    I didn't know if the steel filler of Solder-IT allows you to plate over top or not. Also, could a fiberglass filler be used and then sprayed like you would when preparing cloth for plating?
    Any ideas?
    Thanks in advance.
    Share with Facebook
  2. #2
    Caswell says you can plate directly over pit-stop. I just finished a job and am sorry I didn't use the pit-stop first. You could also try a tin solder, but the pit-stop seems like much less of a hassle.
    Share with Facebook
  3. #3
    Default Filling steel pits before nickel plating
    I'm just getting ready to do this myself on an old revolver-I'm going to use a homogenized solder with a melt temp of 425f. If that does not sail, i will try the above method.
    Share with Facebook
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Plating Nitrocarburized mild steel
    By MrRage in forum Electroplating Questions
    Last Post: 08-19-2005, 01:26 PM
  2. Stamped Steel - Pits and Scratches Problem
    By tglover in forum Metal Polishing Questions
    Last Post: 06-24-2005, 12:37 PM
  3. filling small pits with acid copper
    By danderson in forum Electroplating Questions
    Last Post: 08-25-2004, 07:55 AM
  4. Copper plating on stainless steel 316L strip/sheet
    By slee36 in forum Services Offered/Wanted
    Last Post: 03-31-2004, 12:46 PM
  5. Plating Advice for 12L14 Steel ??
    By kenitd in forum Electroplating Questions
    Last Post: 01-27-2003, 07:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
