Assuming im using lead free solder, can I directly plate copy chrome over solder? I have some small pieces, with odd shapes. They are to odd to sand, and badly pitted. Just wondering if the solder would solve these problems. They don't have to be show quality, just better than they are now.
Also, anyone know where there is an inexpensive tumbler i can buy for small parts? Or will the elcheap o' versions work? I'm needing to polish parts Less than 1 sq" I hate to drop 300.00 + the price for medium materal for one of caswells tumblers? (im sure they are great, but im not polishing anything bigger than 1 sq" |
I have tried nickel plate over lead free solder before and it didn't work. I tried acid copper also and no luck there either. The solder turned dark grey, obviously attacked by the acid in both mixes. I think copy chrome is also acidic. I'm sure it depends on the composition of the solder. There are several different types.
It would be best to flash copper over the solder after you have smooth out the solder on the part. Then you can go to the acid copper for build up.
ill see if I can get you some info on the solder for a small tumbler you might try here http://www.caswellplating.com/buffs/...y_tumblers.htm Last edited by mcaswell; 08-20-2005 at 07:15 PM. |
| triple chrome vs. nickel/chrome vs. copy chrome | spectraflamed | Electroplating Questions | 4 | 01-21-2007 11:07 AM |
| copy chrome vs triple chrome plating | splbnd27 | Electroplating Questions | 18 | 06-21-2006 08:35 AM |
| Copy chrome and resistance to rust, tarnish, dulling? | phunkmastakrez | Copy Chrome Kit Customers Only | 6 | 08-25-2005 10:13 AM |
| Copy Chrome Start-up | Elitefisherman | Electroplating Questions | 10 | 04-18-2004 05:24 AM |
| Copy Chrome Questions | junodale | Electroplating Questions | 13 | 03-17-2004 12:15 PM |
