Connect with Facebook
Old 07-05-2005, 04:13 PM
vona0018
Default Gold Plating
I have a highly technical question. I am gold plating to prevent hydrogen permeation and I am getting different shades of gold. I believe this is because of different surface roughnesses causing different refraction of light. My question is if anyone knows if this can hinder the prevention of hydrogen permeation or if anyone knows another reason why the I am getting different shades?
Thanks
Old 07-05-2005, 11:00 PM
engineerscott is an unknown quantity at this point
Default Hydrogen permeation
One would suspect that a rougher finish would present more surface area. Since the rate of permeation is a function of surface area (and temperature, partial pressure of H2, etc., etc.) then you would expect that as the roughness goes up, the surface area goes up, and the rate of permeation goes up. Therefore a smoother surface should give you lower permeation rates.
Old 07-06-2005, 11:04 AM
vona0018
Now is it not true that I am using gold plating because of its lattice structure, having gaps smaller than the hydrogen atoms. So the surface area should not matter because the gold will prevent H+ from getting through or does gold just stop most H+ atoms.
Thanks
Old 02-08-2009, 02:31 PM
NOL4154's Avatar
NOL4154 is on a distinguished road
Thumbs up Re: Gold Plating
Hello,
Interesting question "Hydrogen Permeation" vs different gold shades?
I not sure but "Hydrogen Permeation" has to do with hydrogen embrittlement were H forms part of the metal structure causing it to be more brittle. I will ask some of my assocates. I plated both in tanks and brush plated gold with different color shades. Check your amps, chemistry, and keep the plater brush well supply with gold solution. Their are different shades of gold which is achieved by adjusting chemistries. Look up trouble-shooting gold plating.
Nol4154
gold plating on brass jomida Electroplating Questions 6 03-28-2009 07:41 PM
gold plating solution gone bad?????? anyone from there ?? clocktools Electroplating Questions 2 08-21-2008 07:44 PM
Question on gold plating oldtoys1961 Electroplating Questions 4 05-07-2008 11:41 PM
Gold Plating and Nickel plating tzmandevil Electroplating Questions 2 09-16-2005 10:11 AM
last step: finishing with wax on gold plating. Which one? didierphmartin Metal Polishing Questions 1 10-29-2004 03:11 AM
