I want to plate some kitchen cabinet hinges and have a bright copper finish. What do I need? What products will work the best? These hinges are small, will the plug n plate work? I plan on a polyurethane or clearcoat to keep it shiny. Feasable?
I have never used a plug-plate system. You will need some way of stripping off the old finish off, whether that be varnish or chrome? You will need a strong cleaner and degreaser prior to plating. I assume the hinges are in good cosmetic shape, if not, they will have to be sanded and buffed proir to plating. I don't know if plug-plate has brighteners in the solution (ask Caswell), if not you will need sisal/emory, spiral/brown and maybe loose/white to get the shine you want. Varnish or clear coat should work fine in a indoor invironment, test first to see if it affects the finished look.
PNP Copper is Flash Copper, so it will go on directly. However, it may be streaky due to the brushing action. You can LIGHTLY polish it to remove this and improve the shine.
Our Clear Lacquer VHT will work well over this.
| Keep getting blisters in flash copper plating...HELP | gtabadboy | Electroplating Questions | 7 | 11-17-2005 08:19 PM |
| I did a dumb thing - now how do I remove copper plating? | Mark3316 | Other Metal Finishing Questions | 0 | 05-19-2005 02:57 PM |
| Differet copper plating questions, plus copy chrome/ nickel? | krsimulis | Electroplating Questions | 1 | 07-26-2004 12:25 AM |
| Copper plating on stainless steel 316L strip/sheet | slee36 | Services Offered/Wanted | 0 | 03-31-2004 12:46 PM |
| NEWBIE Chrome Plating Question???? | suparida | Electroplating Questions | 2 | 06-26-2002 04:10 PM |
