Silvaspray™ - Silver Conductive Paint
I had trouble with my airbrush spraying a smooth finish, but I did get the copper to plate on the paint. The part was a plastic chain gaurd for a sport bike. |
I have never tried this, but a guy on an electroplating forum uses this method, others have tried this and they were successful. Let me know if it works. The plate he is refering to is copper.
NAPA Balkamp # 765-1375 is a 2 oz bottle of superfine graphite. I've been using some clear lacquer I had for clear coating cars and some cheap thinner. 1 oz of lacquer to 7 oz thinner and about 1/4 oz of graphite. I use an airbrush and hold back about 12-14 in with a couple fine coats. After drying completely I take some powdered graphite on a cloth and lightly rub the surface to get a slate grey coating.This will even out the graphite and make a good conductive coat. I start with the lowest amps I could go to start the plating and go to .1-.3 amps/sq.in when I have full coverage. |
Try just mixing the graphite into the lacquer thinner without any lacquer.
Then spray that on. The lacquer will soften the plastic and the graphite will stick to it without any lacquer as a glue. In fact, the graphite is more conductive doing this.
If i mix some superfine graphite & lacquer thinner together and spray that onto to plastic, wait for it to dry, can i then brush plate the coated plastic? Where can i buy superfine graphite in the UK? |
| plating non metal surfaces (plastics for instance) | bigdave | Electroplating Questions | 4 | 06-22-2008 10:26 PM |
| I need A Chrome Plater for Plastics, Decent Volume Job | EurotekDesigns | Services Offered/Wanted | 0 | 03-30-2004 01:40 PM |
| Chrome Plating Plastics and Die Cast Metals? | nunnc | Electroplating Questions | 1 | 05-21-2002 03:45 PM |
| plating plastics | Spencer Wood | Electroplating Questions | 2 | 03-03-2002 08:42 PM |
